Found this on the Wiki though:
"Initially, some PAL Virtual Console games would not display correctly on high-definition televisions when connected via the component lead.
However, starting with the April 13, 2007 update of the PAL Virtual Console, certain newly added games, such as Punch-Out!!, support the
"Wii Component Cable Interlace mode.
" This is a temporary fix to problems with various Virtual Console games being played over component cable on HDTVs.
The mode can be enabled by accessing the operations guide of the game, and
(with the Nunchuk attached) pressing the buttons Z
A
2 simultaneously.
A sound is played if the mode is enabled correctly.
Several older games also have updates available to enable the feature, such as Super Castlevania IV.
The mode can be disabled by using the same method, but with the button combination Z
A
1 instead.
A full list of games supporting this mode is available at nintendo.no,[63]
an English version can be found at vc-forums.com.
Worth a shot at any rate.
