My Tubby is finaly back together, but I have a slight problem with the Apexi Power FC.
Engine spec below:
Engine:
JE Pistons
Eagle Rods
PCI Cam Belt And Tensioner Kit
Sard 800cc Injectors
GFB Light Weight Crank Shaft Pulleys
Stainless Steel Fly Wheel
Paddle Clutch Assembly
OEM Oil Pump
OEM Water Pump
Walbro 275Lts
HKS
HKS 264 Inlet Cam
HKS 264 Exhaust Cam
ARP Crankshaft Bolts
ARP Flywheel Bolts
ARP Head Bolts
Comtech Multi Layer Head Gasket
Sytec Motorsport Fuel Filter
Upgraded Fuel System
Adjustable Fuel Pressure Regulator
Air Impulse Induction System
Large Intercooler
Stage 2 Fensport Hybrid Turbo
Tubular Exhaust Manifold
3" De-cat Pipe
HKS Hiper Exhaust system
Samco Engine Coolant Hose Kit
Engine Management:
Apexi Power FC
Apexi Power FC Boost Controller
Rev2 to Rev3 Engine Management Conversion
3Bar MAP Sensor
Air intake temperature sensor
Inlet manifold temperature sensor
Rev3 Ignighter
4 Wire Lamba Sensor
