[Mk2] [Generic] where did they find that extra bhp in the later revs of N/A's?
DB1
Post by DB1 »
where does the extra bhp come from in the later models?
fearless
Re: [Mk2] [Generic] where did they find that extra bhp in the later revs of N/A's?
Post by fearless »
a different engine all together in the rev 3's onwards and the red top beams engine :thumleft: :thumleft: :thumleft:
Razor04
Post by Razor04 »
around 1996 the N/A engine was changed to a high compression engine making 176bhp this was short lived as in 97 the engine was detuned to 168bhp to keep inline with emmission laws. After this came the legendary BEAMS vvti engine, this is rarer than rocking horse s**t.
Rogue
Post by Rogue »
DB1 wrote:where does the extra bhp come from in the later models?
Major changes to the head design at revision 3 were the primary factor. Later engines lost around four horsepower due to the addition of exhaust gas recirculation (on UK engines only) to meet emissions legislation.
Patrick
genuinita
Post by genuinita »
and they moved the power band up using the cams
gen2 3SGE
In: 244deg, 8.5mm
Ex: 244deg, 8.5mm
gen3 3SGE
In: 252deg, 9.8mm
Ex: 240deg, 8.2mm
Ry_B
Post by Ry_B »
is removing the egr easily done
