The stereo i have only has rear rca outputs, while the adaptor has connectors for both rear and front.
So i connect this one up, with the two rear connectors from the PC9-406 going into the head unit, and the two front connectors going into the rca female adaptors on the PC9-450, and the headunit connector going into the PC9-450.
This might be less confusing if i'd had the correct installation instructions included within the connector instead of one for a stalk control adaptor
