![Image](http://img33.picoodle.com/img/img33/4/7/3/t_DSCF1296m_1e8541a.jpg)
![Image](http://img27.picoodle.com/img/img27/4/7/3/t_DSCF1298m_6a6ca7d.jpg)
87, dark metallic blue, T-bar in good condition, 113k miles
- blue-top engine with C52 gearbox.
Toyota stamps up to 2003, and MOTs for it's whole life; bundles of other receipts included.
MOT 01/09, TAX 07/08.
This car has been in the mr2 mk1 club for a few years too.
Bad points first: starting to bubble on the offside arch, and a couple of small bubbles above the windscreen; and some rust showing at the bottom of the off-side A pillar, and under the bumper at the rear.
The off-side front bumper has been scraped, and there are some slight scratches to the bodywork in general.
The engine occasionally makes a few noises out of the ordinary, but these don't seem to indicate any faults as such.
Drivers seat torn in several places.
Good points: the rest of the bodywork is good, including the nearside wheel arch
- these were both done about 3 years ago, although the receipt for this has gone missing.
The t-bars don't leak
(although occasionally in very heavy rain some water comes in between the top of the passenger window and the roof).
Janspeed exhaust system.
Not even a wobble in fifth gear![](./images/smilies/spacer.gif)
Running on 15" white 6 spoke wheels
(5 x original pepper pot alloys included in sale
- could do with a refurb though to be honest) Short shift gearstick fitted
(original supplied in sale) Maintains good oil pressure.
Toad alarm and immobiliser
Other work done in the last 2 years
/ 13k miles: head-gasket
(and other gaskets) changed; cambelt replaced; throttle cable replaced; radiator, water pump, thermostat replaced; all brake calipers cleaned and painted; near-side rear caliper re-furb'ed; front brake discs replaced; front droplinks, lower balljoints all round and track rod ends replaced.
New clutch.
This car has been well looked after and cared for.
I am moving to Brighton in August, and I can't afford a flat with parking or to keep and run a car down there, hence the sale.
The car is not perfect, but definitely worth a look.
I'm based in Birmingham, give me a call on 07971 417304 as I've probably forgotten to mention something! I'm looking for
£1000.
Cheers,
Neil
