what do you think?
Slarty wrote:I'd say yes, it's possible.Can't say as I've heard of the king lead failing though, as it's not in such a hostile environment as the HT leads.
SimonPearse wrote:If it's worse when damp then the fault is electrical, and probably on the HT side.Next time the fault is showing up try selectively spaying the ignition system with WD40.
When the fault goes away you have found the problem.
The coil
(together with the ignitor) is on the engine/boot bulkhead.
just trace the kinglead from the distributor cap and you will get to it.
HAve you recently removed the undertray?- that can let lots more road-spray into the area.
