Probem is the clutch i got, fits the N/A gearbox, doesn't fit on the SGTE flywheel.The holes on the clutch pressure plate dont line up on the flywheel.
So is it possible to buy a turbo clutch kit(Just to get the pressure plate) and use it with an N/A clutch disc(Which will fit on the N/A gearbox shaft)? Will that work?
Or will a 3sgte clutch kit fit with my N/a gearbox shaft anyway?
Any help/ advice is needed!
