[Mk2] [NA] box under drivers seat
paul port
Re: [Mk2] [NA] box under drivers seat
Post by paul port »
possibly a Jap Spare ordered in through a Toyota Dealer....
I'd hate to know the cost!
Plus who knows how to program it in...?
Paul
ryan
Post by ryan »
cost approx 125 quid. I got quoted this for the original key with button on side of it (not fob type) :pale:
Ishii
Post by Ishii »
The only box under the drivers seat is the Dealer installed wireless central locking receiver. It happens to use a standard stereo receiver antenna lead as the antenna for itself.
The dealer installed wireless remote entry uses a 2 button key transmitter (transmitter built into the key)
The Maker installed wireless remote entry uses a single button (on the side of the key).
If you want to check if your car has the Maker option installed in it:
Close all doors and DO NOT insert the key in the ignition.
Open the drivers door.
press the power door lock switch from Lock to unlock 10 times at 1.0sec intervals
after 2 or 3 sec. the door locks will LOCK and UNLOCK once to confirm.
spooferman
hmm
Post by spooferman »
not that sure, but a friends ripped a black box out from under his rev1 few months ago, had coax running to rear screen. And power direct from engine bay fuse box. Google search on the part numbers, it appears to have been the brain box for an early 90s in car phone, the hand set long time missing
paul port
Post by paul port »
Note Ishii's Location: Yokohama, Japan
Don't you think he's in the best position to know?
axgizmo
Post by axgizmo »
ryan wrote:cost approx 125 quid. I got quoted this for the original key with button on side of it (not fob type) :pale:
it would have been £180 for a new key from Citroen For my AX GTi :shock: so i think thats quite cheap tbh lol
Return to “Electrical”
