[Mk2] [NA] Can anybody reccomend a decent garage near oxford
d4v3
Post by d4v3 »
I was driving home from work last night, approaching a set of red lights. As i lifted off the throttle, i heard a popping sound and now i have a really annoying rattle/grinding noise coming from the rear. It's only noticable when i lift off the throttle and it doesnt get louder/faster with speed. I don't have a clue what it is so I'm gonna take it to a garage. Can anybody reccmend a garage that knows their mr2's near oxford?
Dave :-k
Caribbean_Blue
Re: [Mk2] [NA] Can anybody reccomend a decent garage near oxford
Post by Caribbean_Blue »
Here nearish Oxford:
www.revision6.com
Rogue Motorsport recommended by most on here including myself. :thumleft:
Have you looked yourself for anything obvious like exhast brackets come loose or rubbing on anything etc.
Reece
d4v3
Post by d4v3 »
I did check but there wasnt anything obvious. I have a feeling that its something to do with the gearbox as i've been having problems with it since i bought the car. Thanks for the info mate
Dave
simmo490
Post by simmo490 »
ryan at 2 bar tuning is in oxford ;)
simmo
Sy355
Post by Sy355 »
I'll second the recomendation of Rogue, shouldn't be too far for you from Oxford, an hour and a bit?
Leon.
Post by Leon. »
simmo490 wrote:ryan at 2 bar tuning is in oxford ;)
simmo
2 bar are only a tuning company now :thumleft:
Nathan at Century Motorsport in Kidderminster is another option. All can be found in the Affiliates forum.
dan9
Post by dan9 »
Is the rattle quite "metallic" sounding? It's quite common for the inlet manifold heatshield (why does it have a shield on it anyway?) to come loose and rattle - mainly when you lift off.
Just throwing that out there in case it isn't as serious as you first thought. A 10mm spanner and a very flexible arm/wrist should sort it.
Please don't blame me if your gearbox falls out though : )
I recommend Millway Vehicle Services in Andover - a bit of a trek from Oxford though...
