Is the rattle quite
"metallic" sounding? It's quite common for the inlet manifold heatshield
(why does it have a shield on it anyway?) to come loose and rattle
- mainly when you lift off.
Just throwing that out there in case it isn't as serious as you first thought.
A 10mm spanner and a very flexible arm/wrist should sort it.
Please don't blame me if your gearbox falls out though
I recommend Millway Vehicle Services in Andover
- a bit of a trek from Oxford though.
