[Mk2] [Turbo] Is this a ct20 hybrid
The Morris
Post by The Morris »
Bought this turbo under the impression it was a hybrid running 360fly/300wheels.
Once received i see it has ceramic blades at the exhaust side. Can this still be a hybrid??
Any ideas
Re: [Mk2] [Turbo] Is this a ct20 hybrid
Post by Martin F »
The Morris wrote:Bought this turbo under the impression it was a hybrid running 360fly/300wheels.
Image Replaced With URL For Quote http://i2.photobucket.com/albums/y41/mo ... ent003.jpg
Image Replaced With URL For Quote http://i2.photobucket.com/albums/y41/mo ... ent004.jpg
Any ideas
the hybrid i had before had 6 blades on the intake.... :? does the turbo have a plate on it giving details of it being a hybrid ?
sometimes they can be missed
The Morris
nope all blank
Im thinking its standard, never seen a ct20 so dont know. Seems in good shape with no play, but i wanted a hybrid.
The Morris
just noticed it has a steel shaft. Does the standard ct20 have one??
Post by Martin F »
The Morris wrote:just noticed it has a steel shaft. Does the standard ct20 have one??
no, could be a hybrid or refurbed unless its off a uk gt4 :-k
The Morris
fensport fit steel shafts but not sure if they keep the ceramic exhaust end blades
Post by Martin F »
The Morris wrote:nope all blank
id have too say that the standard ct20 is probably a better turbo the a hybrid ct26 so if this one turns out to be a ct20 hybrid then you should be a happy man...what kind of miles has the turbo done and hope you dont mind but how much did you pay for it ? :wink:
paul_h
Post by paul_h »
some images of a standard one to compare with
looks standard to me :?:
paul
The Morris
it has been on his car for 4 years. No shaft play and is clean. Paid £195
The Morris
speed-tech wrote:some images of a standard one to compare with
Image Replaced With URL For Quote http://homepage.ntlworld.com/bigboned/r ... P01925.jpg
Image Replaced With URL For Quote http://homepage.ntlworld.com/bigboned/r ... CF0014.jpg
paul
Yep looks identical, but this one has a steel shaft and hes positive he was running 300 wbhp, which is the figure i want
Spittinflames
Post by Spittinflames »
So a standard ct20 is a better turbo than my stage 3 hybrid 26 :lol: :lol: Who told you that :lol: :lol:
simmo490
Post by simmo490 »
a standard ct20 is not as good as a hybrid 26.
look how many hybrid 26`s there out there compared to ct20, thats because the 26 is a better base to start.
i took off my ct20 and replaced it with a TT stg 2 ct26 and what a difference
dave
BrianUK
Premium Member
Post by BrianUK »
Looking at the Flange I can count 7 studs (well 6 studs and a hole where a stud should be!)
I was under the impression that the CT26 had a 7 stud fixing to the exhaust, and that the CT20 had a 6 stud fitment?
If thats true - then I would say you have a CT 26...
:) Brian
Sharpey
Post by Sharpey »
Other way round
paul_h
Re: :)
Post by paul_h »
BrianUK wrote:Looking at the Flange I can count 7 studs (well 6 studs and a hole where a stud should be!)
:) Brian
just for your reference, here is the same turbo side by side with a ct26 hybrid :D
paul
Post by Martin F »
lol...i know i shouldnt have posted that but just thought it would be interesting to see who was going to be first to bite :lol: :lol:
ok maybe on 1.3 bar plus the hybrid will kick ass but below that i bet you couldnt beat me in a straight line race :wink:
simmo490
Post by simmo490 »
i dont think there are many people run hybrids over 1.3.
i got to say when i fitted my hybrid my bum dyno said it was more powerfull at the same boost.
simmo
Munnsy
Post by Munnsy »
bum dyn???
not impressed then, or didnt trust it??
SW20Paul
Post by SW20Paul »
simmo490 wrote:i dont think there are many people run hybrids over 1.3.
Plenty of people run there hybrids over 1.3bar its just down to the horrendus boost creep you get from a hybrid :wink: :oldtongue:
The Morris you should get pretty close to 300whp with a stock CT20.
300 @ hubs is the most i've seen from a CT20
greeny
Post by greeny »
Get the revised Turbo technics exhaust housing with the single hole wastegate and theres no boost creep :wink:
