Anything with a torque specified should be torqued to that level.
But generally as long as its done up good and proper you'll be fine.
The torque spec from 1 rev to another won't vary that much, if at all.
However, depending how closely you read the BGB you might notice that there are a few different specs for some bolts.
Think its the flywheel bolts are given a different figure at a couple of points in the BGB.
