I'll try to put the problem as simple as possible because things are getting very messy in my mind now.
Background:
1990 rev 1 N/A
Can buy in the UK since a friend takes care of shipment on a wallet friendly environment.
Always wanted a lightweight flywheel and LSD.
Problems:
- clutch slipping badly
- 2nd gear crunches.
Solutions from less expensive to burning money
(or not):
1st:
- buy a toyota clutch kit and fix the slipping thing
- live with it since if taken easily it changes without crunching
2nd:
- get someone to fix the box
(some guys charge just for replying to the quote question
3rd:
- buy a used NA clutch
(waiting for one since June
4th:
- buy everything tubby
(gearbox, flywheel, clutch and all required bits and pieces
- need some guidance here!!!)
- GTS-ANDY jumps to mind.
What would you guys do?
I'm not swimming in money but I recon I could spend
£500 in parts.
Thanks A LOT guys.
My brain is melting on this specially since I have the car parked for a while trying to figure this out.
Regards,
Vítor
