[Mk2] [Turbo] Spal fans - diy kit
Rev2_mike
Post by Rev2_mike »
I've been noticing that it doesnt seem to take very much to get what seem like very hot engine bay temps - engine lid is too hot to touch after a bit of 'spirited' driving. And was wondering if its worth putting a 10" spal fan or similar in the more open part of the rain shield? Anyone done something like this?
Yes i've seen the rogue one - im just looking for a cheaper way of doing things.
rossdymond3352
Re: [Mk2] [Turbo] Spal fans - diy kit
Post by rossdymond3352 »
I do belive james @ 3s was considering making his own, pm him, only a thought
Ross :thumleft:
cantfindausername
Post by cantfindausername »
I was gonna knock one of these up as all you'd really need is some sheet metal and a couple of spal fans. The KORacing ones are a lot simpler in design to the rogue ones, and I think run bigger fans.
Due to time constraints I got myself a rogue fan kti, Had to rewire it so the connectors we're exposed, replaced both ends of the hydraulic lifter after they both sheared, and will also be getting the relay replaced for a good one. Will have to wait and see how effective it is, but it should pull the air alright in the end.
***RIP Car13 ***
*** Now in an Evo ***
RST
Post by RST »
OK, I don't have a tubby but I noticed after I changed my engine that my engine lid gets roasting as well. I've got a tubby lid and plan on installing a single fan (maybe a 7 or 8"") so it comes on when the car's stationary.
The tubby kits are way over the top for what I need but I'm sure I can do better for the money as well. I need to find someone who can roll me a thin aluminium or steel sheet so I get a nice lip round the edge first -think the guy who made my sills can help.
I might contact your man at 3s as well to see how he did the metal sheet part.
I'll post up pics in my garage when it's done.
Richard
cantfindausername
Just so you know, the corner pieces on the rogue ones are welded on and then ground down on the outer edge. Its then all powder coated.
***RIP Car13 ***
jimGTS
Post by jimGTS »
rogue ones fit very well and look very professional....
if you are going to install just one fan, you really need it on the drivers side of the engine bay.....
my fans expells (spelling) loads of heat, but it definatly is warmer on the drivers side....
i got my rogue fans secondhand, with an uprated relay and fuses, i spliced into my IC SPAL fan as well, so i got that sucking, and the rogue fans blowing, lol =P~ ....all controlled by a switch, which is also wired to the AIT lid sensor, so if i forget to turn the switch on, the sensor will take over when its hot and turn them on automatically (like stock).
tubby_tony
Post by tubby_tony »
mattcambs
Post by mattcambs »
tubby_tony wrote:Have a read of this.
http://www.mr2oc.com/showthread.php?t=2 ... ne+lid+fan
What's it say??? [can't be ar$ed to register on there]
cantfindausername
cant be ar$ed to tell you :wink:
***RIP Car13 ***
mr2-wouter
Post by mr2-wouter »
It's a very good forum i think, anyways.. would be good for you to read. Can make you own vent system for 170 dollar. So like 80 pounds?
Very nice wright up!
jimGTS
Post by jimGTS »
yeh but i bet those fans dont cost what they cost in the US....
if there SPAL fans, of that size your looking at £60+ each.
Rogue
Post by Rogue »
jimGTS wrote:if there SPAL fans, of that size your looking at £60+ each.
http://www.roguemotorsport.com/forms/Pr ... spx?ID=481
We did design a "Basic" fan kit that was just a flat sheet with no hydraulic lifting arm that was significantly cheaper than the "Professional" model that we currently sell, but nobody ordered them so we never put them into production!
Best regards,
Patrick Mortell
Rogue Motorsport Ltd
01676 530222
RST
Post by RST »
Patrick, just to reply to my "I think I can do better for the money" statement; your kit looks great but it's too much of an overkill for me with the double fans I think -I'm going to have a bash myself until you convince me to fit that turbo next year -then I might go for the twin fan kit.
Cheers,
Richard
