Tested the battery output
Tested output of alternator
Also shorted the voltage regulator with no increase in voltage.
Concluded that the alternator was shot.
Did a couple miles stop/start journeys last night, all fine.
Just tested battery
Started up and Alt V went from 13.5V dropping to 12.8V over a couple of mins.
Is the s/h alternator suspect too? Why would the voltmeter fluctuate, loose/weak connection? Car still drives fine with voltmeter not dropping below
It has a black box attached to the side with a connection to the alt output.
All help appreciated.
1986 Mk1a
