My car stood for a while
The car does not like starting at the mo, you need to give it gas to get her fired up.
At low revs 2000 rpm or less the car has real problems trying to hold any kind of revs and trys to cut out.
Also at low revs even if you give it gas it will not hold any sort of smooth rev line, its drops off and picks up all the time.
I have changed, plugs, fuel filter, rotor arm, dizzy cap, tested leads, put fresh v power in, checked fr air leaks, tested compression, checked for error codes.
The only odd thing i have noticed is at the moment the cat 1 alarm keeps chirping at me and sounding when you leave the car.
Any help, info or input will be greatfully received.
