well folks the XS power mani is here, as is the magnex exhaust, so im going to attempt to fit it tomorrow night.
BUT.
1) word is that I should try and undo the mani bolts while they are warm, is there any truth in this rumour?
2) should I use gasket sealer on all the new joints or would the provided gaskets suffice?
3) when rewiring the lamda sensor, is there a particular type of wire that i need? can halfords supply it off the shelf? do I just heat shrink the joint?
4)I am going to heat wrap the mani If that effects number 3!
5) is there a given torque
sorry for all the questions, this is the first mod ive applied to the mr and im keen to get it right!
