[Mk2] [Generic] Boot install
naughtydog
Post by naughtydog »
Hi Guys,
Has any1 installed thier amps in the boot as opposed to the frunk(dont fancy gettin a puncture and have the hassle of getting spare out of the frunk)...Ive got my sub behind the passenger seat which is kool.. I just want 2 relocate my 2 amps into the boot area as its far 2 hot in the car..any ideas!!! Pics!!!! links!!!! would kinda like 2 make it look good as well
Michael
oBladeo
Re: [Mk2] [Generic] Boot install
Post by oBladeo »
I had a problem with over heating amps in the boot when i tried. Filtering the rca cables from engine noise and Filtering the speaker cables from engine noise
I've heard of people running them but not at high ampage.
There are two vents either side of the boot maybe hook a fan onto them for ventalation? But the problem is then is the amount of water that will get in
You could use some sort of oiled filter (like your air filter) to stop the water getting in tho
Munnsy
Post by Munnsy »
ivr recently run all wires to the boot and touch wood i have had no probs at all,
i think it looks alot tidyer in the boot too,
Run wires through engine bay ok, think it was the best thing i ever did :thumleft:
naughtydog
Munnsy wrote:ivr recently run all wires to the boot and touch wood i have had no probs at all,
Hi Mate,
Where about did you enter/exit the engine bat to get to the boot area...could you do me a favour and take a pic!!!!!
Michael
Post by Martin F »
there`s a small hole below the ecu..cut a hole in the rubber and feed some cable through and use a bit of wire to hook it up from your engine bay... :thumleft:
oBladeo
Post by oBladeo »
What amps are you running? I was running a 500 and 1000 mono rms and they kept over heating when i turned it up
naughtydog
Im gonna be using a 800 and a 700 mono
Michael
oBladeo
Post by oBladeo »
sorry mate not a chance without adding some sort of cooling in there
Munnsy
Post by Munnsy »
At the mo im only running the one kenwood 1000w amp, and to be honest i personally cant see any prob with running what you have in mind.
However i have been wrong in the past lol
just run the wires in, and see how you get on mate to be honest.
Like i said i havnt had any probs at all touch wood :thumleft:
Pm me and keep me posted as i would like to know for future reference
dave \:D/
johnnymr2
Post by johnnymr2 »
oBladeo wrote:sorry mate not a chance without adding some sort of cooling in there
quite a statement there mate, surely this is dependant on the efficiency of the amp that you are using. if you have a 1000w amp then this figure will take into account all the power of the amp which is obviously made up of sound and heat, the better the efficiency of the amp the less heat dissapation you will get. also the boot of the 2 isnt that small, how do you think FG installs get on? they put amps into tight locations surrounded by FG which acts as an insulator and they still work. if you are using a half decent amp then heat build up in the boost shouldnt be too much of an issue
oBladeo
Post by oBladeo »
I'm using two alpine m500 which are 550ish rms, a kenwood 600 for the 4 channel and 3.5 farad.
The problem i had was because the engine heat was being transfered to the boot and also the amps created heat. I also had to insulate the cables allot!!. It is possable to do but to have a good system you'll have to do allot of work
Return to “ICE and Security”
