[Mk2] [Turbo] Adjustable camber kits?
blueorb
Post by blueorb »
Can you get an adjustable front camber kit for the Mk2 Turbo?
They are trying to build a prison!
MaXsteri
Re: [Mk2] [Turbo] Adjustable camber kits?
Post by MaXsteri »
Like this? (link)
ENSMR2
Post by ENSMR2 »
Moving to modifications
ducatichick
Post by ducatichick »
sorry to sound naive..but can these be used with teins or dont i need them???
mishadbull
Post by mishadbull »
I use a set with my Tein flex's because I figure that setting camber is more than a either or procedure. With the top mounts you get 2 or 3 different settings where as with a set of camber bolts I get an infinite change between +- 2.5 on the bolts plus whatever I get with the top mounts. That way I can set it up for road, fast road, track, drag, drift, whatever I feel like.
Mike
