[Mk2] [Turbo] Adjustable camber kits?
Can you get an adjustable front camber kit for the Mk2 Turbo?
They are trying to build a prison!
Re: [Mk2] [Turbo] Adjustable camber kits?
Moving to modifications
sorry to sound naive.
.but can these be used with teins or dont i need them???
I use a set with my Tein flex's
because I figure that setting camber is more than a either or procedure.
With the top mounts you get 2 or 3 different settings where as with a set of camber bolts I get an infinite change between
+- 2.5 on the bolts plus whatever I get with the top mounts.
That way I can set it up for road, fast road, track, drag, drift, whatever I feel like.
Mike
Mike
