what options do i have to cut this out?????
lower wrote:when you safe mode do you mean proper safe mode where the ecu cuts the spark whenever it detects boost or just low boost mode?
jimGTS wrote:lower wrote:when you safe mode do you mean proper safe mode where the ecu cuts the spark whenever it detects boost or just low boost mode?
low boost mode i think, it came back on when i booted it again(yesturday in the sun).
but in cold, i know the bu88er wont full boost unless its been running 30mins(in my experience).
BenF wrote:jimGTS wrote:lower wrote:when you safe mode do you mean proper safe mode where the ecu cuts the spark whenever it detects boost or just low boost mode?
Jim, I'm 99% sure there isn't a'hot' boost cut on a Rev2.
I've driven mine in Europe with engine bay amblient temps around 30-40C and not had any boost cut.
You will get boost cut when its colder than 4-6C- I posted details a while back of how to remove it.
Search for VSV and you should find the post with some circuit diagrams showing how you can electronically over-ride the VSV.
