Boost Gauge Install
L0rdMike
Boost Gauge Install
Post by L0rdMike »
Ok I want to install my new gauge, question is On my Rev3 I can see the pipe comming from under the sensor which goes into the silver thing (manifold?)
I have my T piece and all that, do I have to cut into this pipe for the gauge or is there another way?
I have looked at the guide but the pics aint to good. Just want to be sure thanks. :)
L0rdMike
Re: Boost Gauge Install
Post by L0rdMike »
Heres a pic of someone elses.
Mine looks a bit different to that though.
poyntesm
Post by poyntesm »
djlee_dj
Post by djlee_dj »
were did you run the piping ?
i ran mine from the picture above .... in through the grommet behind the drivers seat. .... were do i go from here ?
im unsure where im going to locate it. probably custmise to fit under the radio or in the ashtray
my supplied pipe is quite soft. and dont want to crush it .
everyone elses soft ? what is suitable for replacement piping
poyntesm
Post by poyntesm »
The pressure pipe goes into my control CPU as per the post!! See point 14)
The SBC iD III controller wire then goes from the control CPU to the controller face. That part is not shown as its up to each owner to decide where to mount that. I mounted mine in one of the DIN slots as I had a powermeter ID
Every boost controller/guage is different..that write was just to show how to tap the pressure and how to bring a cable through.
You can see it mounted http://www.imoc.co.uk/forums/garage.php ... ge_id=2422
jimGTS
Post by jimGTS »
thats my pic, lol...
:mrgreen:
easy place to T into.
djlee_dj
Post by djlee_dj »
yeah mines been t-d there before
where do people recommend to run my pipeing ?
along door sills and up behine dash, along centre section
bearing in mind it cant be squeezed into places ...
thanks (hope this helps the thread authour too)
jimGTS
Post by jimGTS »
i ran mine under the door sill....to behind the dash for my ebc...
L0rdMike
Post by L0rdMike »
Cheers guys, was just woried about cutting the pipe, and the Rev3 looks a bit different from some pics I seen.
djlee_dj
Post by djlee_dj »
thanks from me 2
Turbo-G
Post by Turbo-G »
You could always just change the pipe mate to something of good quality. Washer jet hose has a stiffer sidewall than most silicone hose, I have a combo of this and proper nylon tubing from a decent boost guage in all the areas it could get crushed,
MK_Steve
Post by MK_Steve »
Will be plumbing mine in this weekend. So the T goes above the white thing then? Or doesnt it make a difference? What is that white thing anyway? :lol:
Where can I buy peices to join the tubing to extend it a bit?
Steve
jimGTS
Post by jimGTS »
t in where i have in that pic, no idea the reason for it :?
joiners, go to a pet stoor and buy some t, y and straight joiners that are used for fish tanks, dead cheap!
EarL
Post by EarL »
The pipe can be teed into that place, or better still, taken from the blank take off on the under side of the inlet plenum (difficult to see though).
From there, it can be fed through either the passenger side, or the driver side gromments in the firewall. I used the passenger side, as my e-01 EBC's solonoid is fitted to the bulhead right next to the opening on the passenger side.
As the pipe comes into the cabin from behind either the driver or passenger seat, it can be routed down the centre console, or down the sill. Personal preference. Mine is down the centre console, as it was just easier.
From there, mine goes under the dash, and is fed up the driver side pillar to the guage, which is in a custom pod.
The job isn't hard, but it is a little awkward in places.
EarL.
L0rdMike
Post by L0rdMike »
Just done mine
13psi in 3rd
14psi in 4th
Ok a question my T-Piece and a smaller hole on one exit, has some brass copper thing in it. What bit should this be connected to.
djlee_dj
Post by djlee_dj »
PSI or Bar ?
which gauage ?
i bought a Bar gauge
