Hi Nathan,
Sorry i havent got on here until now, was great to meet you and play with your car.
The day couldnt have been better for me, you said you would be happy with 400+hp.
Your face was spot on when i came out first round and asked where you wanted me to stop as it had made over 400
@1.4bar
:p
501.8hp was made at 1.7bar, due to the charateristics of dyno's the boost comes on later which meant the boost was on hard past the surge line, unfortunately on the road this is a different matter and any more than 1.55bar meant heavy compressor surge when teh turbo spools up.
Easily sorted though, make sure you sort that out Nath.
All markings would suggest its a HKS t04S, of the older generation.
Ryan, you were very close with your guess of power on Johns car, 395hp
@ 1.6bar.
not bad power at the wheels though
John's not to be confused with Nathans which made more.
Thermocouple was showing 35degrees on nathans on the road, whilst the MAT sensor was showing 62deg.
Once again, a good day and i'll look forward to seeing your car at the pod Nath
(if you get a day off
Rob
