please people.
I'm thinking 215 on the front and 235 on rear.
quigonjay wrote:205/40/17 and 245/35/17 would keep the same rolling radius as stock 15's
but thats too big of a difference you may think?
well, on that particular size(205/40/17), its only a guide
- 205mm minimum, the toyo T1R for instance in that size is actually 219mm wide
jimGTS wrote:245/40(this will send out speedo a tiny bit more, but nothing to worry about, i might go this size next)
matt_mr2t wrote:Is it for an MR2 Draven?
Does any one know if 245 is ok in a 7.5" wide wheel?
jimGTS wrote:i say your only real options are
7j and 8j
front
215/40
rear
235/40
245/35
7j and 8j
front
215/40
rear
235/40
245/35
jimGTS wrote:obviously they have otherwise we wouldnt be suggesting a 245/35 instead of the usual same wall height all round.
(ie 40 all round).
245/35 is closer to stock as your gona get on 17s with a 245 tyre..
