Wheels... Best tyre sizes ? please reply quick
Draven
Post by Draven »
With 7JJ on front and 8 JJ on back...
please people... this is to help a girl out.. She's really nice. !!!
I'm thinking 215 on the front and 235 on rear... .
[-o<
:mrgreen:
Adam J
Re: Wheels... Best tyre sizes ? please reply quick
Post by Adam J »
Sounds good to me, Tis what Im using and it works well, think (but will probably get slated) The wider the back the better, but you dont really want wider than 215 on the front. What size rim?
jonb-
Post by jonb- »
205/225 also fit just fine.
steve
Post by steve »
215/245 are also fine
jimGTS
Post by jimGTS »
16s or 17s.....
Draven
Post by Draven »
17...
7JJ on front and 8JJ on rear...
Ta
People..
Quigonjay
Post by Quigonjay »
205/40/17 and 245/35/17 would keep the same rolling radius as stock 15's
but thats too big of a difference you may think?
well, on that particular size (205/40/17), its only a guide - 205mm minimum, the toyo T1R for instance in that size is actually 219mm wide :wink:
quigonjay wrote:205/40/17 and 245/35/17 would keep the same rolling radius as stock 15's
245/35/17 rear
215/40/17 front
:D
cantfindausername
Post by cantfindausername »
I used to have 215/40 17 (front) 235/40 17 (rear)
***RIP Car13 ***
*** Now in an Evo ***
jimGTS
Post by jimGTS »
i say your only real options are
7j and 8j
front
215/40
rear
235/40
245/35
245/40 (this will send out speedo a tiny bit more, but nothing to worry about, i might go this size next)
Leon.
Post by Leon. »
jimGTS wrote:245/40 (this will send out speedo a tiny bit more, but nothing to worry about, i might go this size next)
Won't it also reduce your acceleration a bit :?
jimGTS
Post by jimGTS »
nothing youd actually notice im sure......altho i havent experience of this size.
matt_mr2t
Post by matt_mr2t »
Is it for an MR2 Draven?
Does any one know if 245 is ok in a 7.5" wide wheel?
matt_mr2t wrote:Is it for an MR2 Draven?
I wouldn't go for that. 245s on 17x8"+ IMO
EarL
Post by EarL »
jimGTS wrote:i say your only real options are
7j and 8j
front
215/40
rear
235/40
245/35
Spot on Jimbo.
Perfect size...
215x40x17 Front
245x40x17 Rear
:wink:
EarL
Post by EarL »
7j and 8j
front
215/40
rear
235/40
245/35
Spot on Jimbo.
Perfect size...
215x40x17 Front (7.5J rim)
245x40x17 Rear (8.5J rim)
:wink:
jimGTS
Post by jimGTS »
so spot on you said it twice!
thanks
:tongue:
Leon.
Post by Leon. »
i thought the rears should be 245/35 to maintain stock rolling radius? Has anyone physically measured th distance of both options and compared with stock :-k
A 40 wall will give slightly better comfort I suppose...
jimGTS
Post by jimGTS »
obviously they have otherwise we wouldnt be suggesting a 245/35 instead of the usual same wall height all round.
(ie 40 all round).....
245/35 is closer to stock as your gona get on 17s with a 245 tyre...
Leon.
Post by Leon. »
jimGTS wrote:obviously they have otherwise we wouldnt be suggesting a 245/35 instead of the usual same wall height all round.
so why are you and Earl suggesting a 40 profile on the rears then???
#-o
