help?
First thing i did was pull each lead off which showed that cylinder one was down.The lead was firing so i plugged one of jims old injectors into the cyl one connector and it wasnt working.
The connector has 12v feed
The signal wire has continuity from the ecu pin to the connector
Supplying earth to the ecu pin with the ignition on fires the injector
Supplying the correct pulse width and duty cycle using our tool brings the cylinder back.
Diagnosis is that the injector driver has died on the power fc, there is absolutely no output from the power fc on injector 1.
