I will remove it at the weekend and check to see what spec we have.
I am not picking holes or destroying work,but simply trying to find out what the problems are and how to solve them.
I will also make moves to wrap the entire exhaust to the back box as this is directly above the intake for the fans to the IC.
The IC is shrouded off completely from the the trunk atmosphere.
I agree james,no high performance/tuned car of any make hits the no's staright away on 1st dyno,there are always learning curves/complications.
I think i will also have some piping made up to lay a new IC flat on the floor rather than up against the rear panel.
The air speed through the IC seems quite high though.
so,with a combo of the list of things i can change,is it likely that i will see another 100hp+ 1krpms earlier,i like to think so as its adding up in favour of the ic temps+timing.
