well it kills me to do this but my pride and joy has to go up for sale due to rather unfortunate events :upset: .
i've owned the car for 2 years, and its never put a foot wrong runs flawlessly. now for the basic info on the car:
1994 Rev 3 mr2 turbo
M registered, 1 jap owner and im the 1st UK owner
car had 36,474 miles on it when imported, now has 39,600 miles on it all of which have been dry weather miles.
car has just had oil changed (silkolene pros 10w-50), new coolant (toyota red), new plugs and leads.
new beake pads front and rear 200 miles ago.
car currently is off the road for winter so no tax but will tax before sale
Mot'd until april
the car is in immaculate condition inside and out, see pics + Huge spec below
now enough of the pics heres the spec:
Engine, Head + Block
Eagle Con Rods
TTE grp A crank
TRD main bearings + Con rod bearings
Ported + Polished head
Exhaust manifold + head port matched
Ferrea 1mm Oversized intake + Exhaust Valves
HKS double valve springs
HKS 87mm pistons 8.5:1 comp ratio (overbores block to 2043cc)
HKS 1.6mm steel HG (Lowers comp ratio to 8.1:1)
HKS 272 cams (IN + EX)
HKS cam gears
ARP head studs
ARP flywheel bolts
ARP conrod bolts
Jun Lightweight Flywheel
Fueling
850cc side feed injectors
SARD fuel rail
SARD 1:1 rising rate FPR
EARLS fuel lines (tank to rail)
WALBRO 044 main pump
Turbo + Exhaust
Ported exhaust manifold
Blitz K3 turbo - (altough may be changing to blitz k1 380-V, as k3 kit may be sold)
Custom downpipe (if sold with K1 will be standard turbo elbow and blitz decat pipe)
Apexi N1 spec exhaust system
Custom Induction kit
Cooling
Under trunk mounted triple row intercooler
Custom IC piping
13 row phoenix power oil cooler
Electronics (ECU etc)
Apexi power FC
Apexi power FC boost controller
Apexi rev speed meter
GREDDY boost gauge
GREDDY oil temp gauge
Blitz turbo timer
Suspension
Apexi N1 circuit spec coilovers
Cusco Camber adjustable top mounts (front)
Cusco strut braces front + rear
REV 2 tie rods (castor adjustable)
Transmission
Cusco triple plate clutch
Zero sports short shift kit
Rebuilt gearbox
Exterior
Arc twin GT rear wing
KEI office front bumper
KEI office side skirts
Wheels + Brakes
BBS LMs 17 x 7 front, 17 x 9 rear
Cusco brake master cylinder stopper
As said previously its breaking my heart to have to sell it but it cant be avoided.
looking for £7500 o.v.n.o
contact me via PM, or alternatively email me at [email protected], from there i will give out my phone number.
cheers for looking scott
[FINALIZED] Mr2 Turbo for sale Huge spec.
Re: [FINALIZED] Mr2 Turbo for sale Huge spec.
Lovely car mate and great spec! Any idea what power she's running?
last time the car was RR, it made 265whp and 256ft/lb of torque @ .7bar of boost (this was with the K1 380-V turbo), mow has the K3-T on it at same boost level, not been dyno'd with this turbo.
although looks like i have a buyer for the K3 kit so the K1 is going back on (hence the price, if it was being sold with the K3 i'd be looking for 8k), the K1 will handle up to 1.4bar.
OMG it`s a beaut if i had the cash i would 100% buy it!!
mate, This is one of the nicest two's. Ill give you my gf and 5k
ilogik wrote:mate, This is one of the nicest two's. Ill give you my gf and 5k
haha, well depends what she's like and whether she can make a good meal or not? also must be good at keeping the house tidy im a stickler for cleanliness
on a more serious not thanks for the comments guys,
somone must want a super clean, well spec'd mr2
sensible offers will be considered as it really has to go
cheeky bump
come on guys make me an offer for her as she needs to go pronto so a sensible offer will more than likely be accepted
sorry m8 all i have to offer is 4,500K or i`ll swap you for a rev 5 n/a.
If you don't mind me asking: you have a specially built engine with custom turbo on it, but only running 0.7 bar boost Why such low boost? Standard Rev3 with the OE CT20B is already running 0.9 Bar.
Wouldn't this engine be able to handle just about double the boost that it is running now, giving massive HP??
what sort of sensible offers are you looking for?
rsevo6 wrote:If you don't mind me asking: you have a specially built engine with custom turbo on it, but only running 0.7 bar boost Why such low boost? Standard Rev3 with the OE CT20B is already running 0.9 Bar.
first off nope i dont mind you asking , to answer your questions, the low boost well why not? the low boost was selected as when the car was mapped i wanted to see the results it could give on low boost. after driving the car like this it was still pretty quick and i've been content with it since then, hence why i haven't bothered number chasing and turning the boost up.
also yes the engine would easily handle double the boost it currently runs, and more. will be good for 2bar (with the correct mapping)
platmatt8:
make offers via PM and if they are within what i call sensible then i'll obviously accept [/quote]
How much
Hiya,more than a little interested in your car,could you contact me at [email protected] to talk about ££££££££££££££
theskippy7, you should now have an email from myself
Hi all no longer for sale
I cant bare to part with it
This Sale has been completed. The Buyer was None
