Hi folks!
My drivers side window has recently started to squeek when lowering or rising. Is it the runners needing a bit of grease?
Cheers in advance,
Leon
Mine had a REALLY bad squeak, only when it was cold though !
Just removed the door panel and WD'd the offending rail, in my case it was the main horizontal one, thank god for the straw
Wish I had done it sooner really......
Dont know whether you need this, but it might be of use.... http://www.turbomr2.com/MR2/HowTo/Door% ... el_PG1.htm
The only thing I would add, is that a couple of times I have done this, and once the card/panel is free it still wont actually quite come off. Putting the window down a few inches released it.
Hope this helps
