manual boost controller?
Range
Post by Range »
im thinking of uping the boost a little on my rev2, but im running a bit low on funds as iv just spent 500 on shocks, the car feels much more stable and wouldant mind going a bit quicker, any 1 got any ideas? :?
Spittinflames
Re: manual boost controller?
Post by Spittinflames »
You answered your own question..... MBC but you will need an FCD too.
Make sure your engines healthy too... and dont go crazy with uppin the boost.
Range
Post by Range »
MBC FCD ABC HUH? sory im abit slow wots mbc :oops:
paul port
Post by paul port »
Range wrote:MBC FCD ABC HUH? sory im abit slow wots mbc :oops:
Manual Boost Controller :mrgreen:
Dale V
Post by Dale V »
mbc - manual boost controller
FCD - Fuel cut defender
Range
Post by Range »
i new that, i was just checking ](*,)
Range
Post by Range »
theres a device attached to the ecu on my car, and its writen on it SPEED CUT DEFENCER its a HKS brand, is this the same as fcd?
paul port
Post by paul port »
Range wrote:theres a device attached to the ecu on my car, and its writen on it SPEED CUT DEFENCER its a HKS brand, is this the same as fcd?
No,
It removes the SPEED limiter (180Km/h)
Range
Post by Range »
wel surly thats got to do with cuting the fuel off to the engine wen it hits a cirtain speed?
screech205
Post by screech205 »
Yes it has mate but that removes the 112mph speed limit, a FCD will remove the fuel cut from when you go above 13psi i think it is. Completely unrelated!
JAP BOY
Post by JAP BOY »
How can you up the boost accurately with a MBc guyz!
I've got a Revision 6 MBC so at the moment i would assume that itz set as standard!
My actuator wont run anything below 14psi of boost! So does this mean that my MBC was setup for more boost i'm just assuming itz just been put on no adjustments
Range
Post by Range »
ooo riite I GET IT NOW. No 1 told me it stops fueling at 13 psi, so every time i see my boost gauge going past 13 or so the car will stall back agresivly? THAT MUST HAVE BEEN THE PROBLEM WITH MY PRIVIOSE MR2!
AN I THUOGHT THERE WAS SOMETHING WRONG #-o
Range
Post by Range »
[ye mate that must be it the actuater is too weak for going past 13 or 14 or so ul need a stronger 1 or 1 u can udjust , i think..]How can you up the boost accurately with a MBc guyz!
My actuator wont run anything below 14psi of boost! So does this mean that my MBC was setup for more boost i'm just assuming itz just been put on no adjustments[/quote]
JAP BOY
Post by JAP BOY »
Hi Range i'm jsu guessing here as my car had a uprated actuator fitted to it!
Range
Post by Range »
ohh sory i miss understood, i thuoght u meant u couldant hold more than 14psi of boost because of ur actuator... hmm i dont no the answere to ur sitaution mate :roll:
CosmosblueMR2
Post by CosmosblueMR2 »
JAP BOY wrote:How can you up the boost accurately with a MBc guyz!
you use a Good aftermarket Boost gauge.. set your MBC - take it for a drive (cautiously) and adjust the screw accordingly to set your desired boost limit.
Car now Sold :cry: damn 5th Lumber Disc !
JAP BOY
Post by JAP BOY »
Cheers Cosmos Blue will do that
