the little nipple twisty thing just didnt fit round the big metal thing
it screwed on a tiny bit, but then wouldnt budge!
im pretty sure it has to screw up the whole way.
help!
Skywalker wrote:what the fook kinda boost gauge is that?!?
Mine just had a gauge, a pipe, and two wires![]()
I'd have thought the gold metal(little twisty nipple thing) screws into the back of the gauge, and the black tuning plumbs into that, with a cable tie.
I have no clue what the other bits are, so I could be very, very wrong.![]()
Dave Goodhand wrote:It doesn't screw"all" the way on.
You need to get 2 open ended spanners and just screw it up as tight as it'll go(as mine looked a bit like this) and this is what I did.
Works all well now, so can only presume thats what yours does.
BTW..
mine didn't tighten up all the way up, it had a about 4 threads left showing.
Dave Goodhand wrote:Oh right..
I don't know then.
As mine didn't have anything apart from a small part like that, that screwed onto the sender unit.To be honest, if you screw it up and connect it together and it doesn't work.
then something is wrong.
I'm gathering it didn't come with instructions..
mine did but they were a joke.
Just a very poor wiring diagram, and a drawing of how the parts go together.
If you like I'll take some pics of how mine is set up(as it looks fairly similar
(although I have a digital gauge) and post them up on friday
(as I'm not in work 2mo)
Dave Goodhand wrote:Pics as promised mate.![]()
You can see that my sender consisted of 3 different brass bits, which aren't done up"all" the way, but are damn tight! lol
HTH
