Where Is Boost Read?
matt_mr2t
Post by matt_mr2t »
At the turbo or at the inlet?
Mark Edwards
Re: Where Is Boost Read?
Post by Mark Edwards »
Inlet manifold as that's what is going into the engine.
xxxx, AM TUNING, sbITs
jimGTS
Post by jimGTS »
Mark Edwards wrote:Inlet manifold as that's what is going into the engine.
(if you wanted to setup a guage);
so it shouldnt be connected to the boost controller hoses?
so anywhere like the bov pipe, map sensor plug, something like that yeh?
matt_mr2t
Post by matt_mr2t »
So that means my turbo is actually boosting to prob a fair bit more than 1.2 bar.
Once I change the intercooler to one with a better flow rate will I then have to re-adjust my avcr to compensate?
Mark Edwards
matt_mr2t wrote:Once I change the intercooler to one with a better flow rate will I then have to re-adjust my avcr to compensate?
More than likely yes.
Mark Edwards
Not to the controller hoses no. :shock:
jimGTS wrote:so anywhere like the bov pipe, map sensor plug, something like that yeh?
All fed from the inlet manifold mate so same as i said. 8)
MARKTURBO21
Post by MARKTURBO21 »
my boost gauge was being read from the pipe what goes from the standard toyota bov to the inlet manifold
now i have changed to a turbo xs bov do i plumb it in the same or is it not a good reading from here
Mark Edwards
MARKTURBO21 wrote:my boost gauge was being read from the pipe what goes from the standard toyota bov to the inlet manifold
Should still be fine, any of the vacuum pipes that come from the inlet plenum will do.
MARKTURBO21
ok i will plumb it back in as soon as my car is back from garage
adamshaw
Post by adamshaw »
I posted to do with this a bit ago.
there is actually an unused area to get a reading from.
if you look down the back wall by the boot catch and look down that gap.
off the back of the "twin entry turbo" bit is a tiny bit of pipe capped off. Apparently you get6 a better reading off this
Ad
JekylandHyde
Post by JekylandHyde »
More than likely no.
Your boost controller is set up by what boost it is reading at the intake manifold. By installing a better intercooler you will most likely have less pressure drop and the end result will be your turbo working LESS hard to make the same amount of boost ;)
___________________________
440 RWHP/365 RWTQ @ 22 psi · 11.44@120 mph
Thank you 2006 Hyde Sponsors!
Chico Race Works,Wolfkatz, Spaz Chicken, TWOSRUS, MR2OC, Chase Cam, KBOX,
ATS Racing,Full Race, Racing Strong, TURBOHOSES, NoShoes, Tomg,
Safe Drives, Spiral Moons, Sandra & not12listen, Jeff Herstine, Ardell & Bob Simon
