Where Is Boost Read?
At the turbo or at the inlet?
Re: Where Is Boost Read?
Inlet manifold as that's what is going into the engine.
Mark Edwards wrote:Inlet manifold as that's what is going into the engine.
so it shouldnt be connected to the boost controller hoses?
so anywhere like the bov pipe, map sensor plug, something like that yeh?
So that means my turbo is actually boosting to prob a fair bit more than 1.2 bar.
Once I change the intercooler to one with a better flow rate will I then have to re-adjust my avcr to compensate?
matt_mr2t wrote:Once I change the intercooler to one with a better flow rate will I then have to re-adjust my avcr to compensate?
More than likely yes.
jimGTS wrote:Mark Edwards wrote:Inlet manifold as that's what is going into the engine.
(if you wanted to setup a guage);
Not to the controller hoses no.
jimGTS wrote:so anywhere like the bov pipe, map sensor plug, something like that yeh?
All fed from the inlet manifold mate so same as i said.
my boost gauge was being read from the pipe what goes from the standard toyota bov to the inlet manifold
now i have changed to a turbo xs bov do i plumb it in the same or is it not a good reading from here
MARKTURBO21 wrote:my boost gauge was being read from the pipe what goes from the standard toyota bov to the inlet manifold
Should still be fine, any of the vacuum pipes that come from the inlet plenum will do.
ok i will plumb it back in as soon as my car is back from garage
I posted to do with this a bit ago.
there is actually an unused area to get a reading from.
if you look down the back wall by the boot catch and look down that gap.
off the back of the
"twin entry turbo" bit is a tiny bit of pipe capped off.
Apparently you get6 a better reading off this
Ad
off the back of the
Ad
More than likely no.
Your boost controller is set up by what boost it is reading at the intake manifold.
___________________________
