leaky t-bar roof
chevva1
leaky t-bar roof
Post by chevva1 »
i just recently have been getting a wet leg,so i decided to try and seal the roof with silicone sealer spray to no joy,so i decided to try and seal the roof with some silicone which i brought from halfords which was black but still got a wet leg.this morning i took off the door panel and made the window stoppers higher which made a perfect seal and not one drip now.just thought id share this with you all as the wet leg really got on my nerves :wink:
Kevin
Re: leaky t-bar roof
Post by Kevin »
Hi, not quite sure what you mean, have you adjusted the stop point of the window?
I've got the same problem and have tried the black silicon filler ploy without any long term sucess :cry:
on the old forum there was mention of modifed off centre locking pins with the necessary part numbers from Toyota that I was hoping to try but all the help sheets have dissapeared in the revamp.
Anyone know of the part numbers, even better have a copy of the instructions to change the pins?
TIA
Kevin
Post by Kevin »
ain't it always the way :oops:
http://www.imoc.co.uk/forums/viewtopic.php?t=226
2 minutes after I posted.
Still, if anyone has the instrictions / how to on their HDD somewhere I'd still appreciate a copy.
I'll be ordering the pins first thing so I'll get them ASAP
chevva1
Post by chevva1 »
yea,all i did was remove the door panel and undo the two window stoppers (one at a time ) moving them slighty up then tightened them back up.my leak has completly stopped now and it only took me about 20 minutes to sort out and no more wet leg.if it drips on your leg then this should work,just wish i had of done it first rather than waste time sealing it etc as i removed all the sealer cause it made the leak worse.when your door is shut and window is up just check to see if the window fits tight up to the t-bar roof as i had a tiny gap and thats where the leak was from :D
raptor95GTS
Post by raptor95GTS »
chevva1 wrote:i just recently have been getting a wet leg,so i decided to try and seal the roof with silicone sealer spray to no joy,so i decided to try and seal the roof with some silicone which i brought from halfords which was black but still got a wet leg.this morning i took off the door panel and made the window stoppers higher which made a perfect seal and not one drip now.just thought id share this with you all as the wet leg really got on my nerves :wink:
mmm the sealant worked perfect in my case but maybe I was just lucky ;)
Kevin
Post by Kevin »
Well - I picked up the offset pin guides and fitted them yesterday :)
They feel 'tighter' when the glass is closed so I have high hopes
Just waiting for a run in the rain to see if things have improved......
I took a number of piccies as I changed the guides, would there be any benefit in knocking up a guide with photos do you think?
Would take an hour or so, so no biggie if it would be of help.
simmy01
Post by simmy01 »
Hi there how much were the offset pins and did you get them from toyota. Were they easy to fit]
Kevin
Post by Kevin »
Yeah - toyota main dealer
followed the instructions on Alans web site here
It has the part number.
I think they will cost you about £20 (I got them for £10 trade)for the both sides
