I know theres a mod that you can do where all 4 rear lights work as normal and brake lights, and you have to relocate the fog light into one of the reverse light spaces
thanks
dave
Mike Stewart wrote:im interested in this also, but my fog lights at the back are not the complete cirle like the tail light!is there any way to make it into the full circle?
Skywalker wrote:Mine are kinda like that.When my lights are on all four are on, then the outside pair are brakes, and the inside pair are fogs.
No need to mess with the reverse lights then.
Leeroy wrote:Stef,
Great stuff..
just picked up the post.
Could you just confirm whether the wiring suggestions would be the same for me.
I have a UK spec car where outer 2 rears are both dedicated side lights and brake lights, and inner 2 are dedicated fogs
Cheers![]()
Dunc wrote:You mean like this?
I too chopped up a Toyota loom!
Hope this helps,
Dunc
g wrote:i did this mod the easy way(albeit at cost) by buying another wiring loom from toyota at about
£20 and replacing the old inside bulb holder with the outside bulb holder of new loom and wiring the old fog light to one of the reverse lights
