As I had the ECU repaired recently, Im wary that the ECU just make not be working correctly even post being repaired.
Happy to donate beer tokens.
Driftlimits Performance wrote:Hiya,
We most likely have some on the shelf if you are local to Hertfordshire and would be happy for you to pop up and test them.
Feel free to give us a call on 01442 601301.
We have quite a few ECU's on the shelf but if you can let us know whether it is turbo or n/a and what year it then we can make sure to have one out and ready for you.
Kind regards
Lily
pbmr2 wrote:rev5 can be tricky as lots changed that year.![]()
There is a number on the ECU, what is it?
Rev5 turbos are not that common so it's possible you have an NA ecu.![]()
The rev4+ had different plugs/layout to the first 3 revs, rev5 had other changes too.![]()
Do you know the year of the turbo engine?
pics help for the ECU, plugs and engine.I host them on Imgur.com as it's free.
I only have NA ECU spare so can't help with parts this time.
