Anyone have a Rev3+ ECU I can borrow / test with?
killerferret666
Post by killerferret666 »
Im unsure If i have a lambda or ECU issue.
As I had the ECU repaired recently, Im wary that the ECU just make not be working correctly even post being repaired.
Happy to donate beer tokens....and of course buy the ECU if required and for sale :lol:
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
pbmr2
Re: Anyone have a Rev3+ ECU I can borrow / test with?
Post by pbmr2 »
what engine? (3sfe, 3sge, 3sgte)
what year?
where are you located?
killerferret666
I forgot to put location.
I'm in Poole. 3s-GTE
I'm running a rev 2 with rev3 conversion.
Are all ECU's Rev3+ the same? (pin wise)
I think the ECU may of been out or a Rev5, as he found out the rev3 conversion was runnign a SARd board in it so took a Rev5 ECU and put that in with the conversion. (I think)
I only fitted the conversio nend of last year and the car isnt used in the winter, so still finding out things
Last edited by killerferret666 on Mon May 14, 2018 3:29 pm, edited 1 time in total.
Driftlimits Performance
IMOC Affiliated Company
Hiya,
We most likely have some on the shelf if you are local to Hertfordshire and would be happy for you to pop up and test them.
Feel free to give us a call on 01442 601301.
We have quite a few ECU's on the shelf but if you can let us know whether it is turbo or n/a and what year it then we can make sure to have one out and ready for you.
Kind regards
Lily
killerferret666
Driftlimits Performance wrote:Hiya,
Kind regards
Lily
thanks for the offer Lily, I couldnt be further away :(
pbmr2
Post by pbmr2 »
rev5 can be tricky as lots changed that year.
There is a number on the ECU, what is it?
Rev5 turbos are not that common so it's possible you have an NA ecu.
The rev4+ had different plugs/layout to the first 3 revs, rev5 had other changes too.
Do you know the year of the turbo engine?
pics help for the ECU, plugs and engine. I host them on Imgur.com as it's free.
I only have NA ECU spare so can't help with parts this time.
killerferret666
pbmr2 wrote:rev5 can be tricky as lots changed that year.
Thanks for the detailed reply. Its definitely not a NA ECU for sure.
I use imgur as well, The outside of the ECU is useless to for reading the number on the sticker, its all gone. Are they located on the boards anywhere?
the engine is a rev2 I know that, with a rev 3 conversion.
Its definitely a re-pinned rev2 loom as it has the single wire Lambda sensor.
I found out the Rev5 it came from was a UK NA car with the conversion done many years ago, so will almost definitely be a rev3.
link to the current photo I have when I found a capacitor gone, incase its of use.
https://i.imgur.com/kYVV7Fb.jpg
SonicSW20
Post by SonicSW20 »
All Gen3 3SGTE MR2 ECU's are the same - http://japan-parts.eu/toyota/jp/1997/mr ... stem#89661
Celica ST205 ECU's are different, but compatible.
killerferret666
Opened the ECU again today and found what I presume is the number
