it doesnt see pressure, so on my setup i dont even have clamps where i have a join
craig wrote:Same.Currently running a KO racing intake pipe and 4" K&N filter.
jimGTS wrote:craig wrote:Same.Currently running a KO racing intake pipe and 4" K&N filter.
likely easier as you are running a stock turbo
these aftermarket turbos require adapters which lower the turbo further(so the KO wouldnt work).
androo007 wrote:Good to have a heads up and WOW those engines look ace! Although you've just made me realise I've bought the wrong CC core..
i need front
/ back option
- Although perhaps i could go top right to try and get it away from engine heat.
How do you find you IAT's by the way Dale?
the adaptor block is only like 2" so should be ok.Better to go in eyes open
