My latest MR2
30n/mm front and 35.5n/mm rear
which I believe is around:
3.1 kg/mm front and 3.6 kg/mm rear
I was expecting the spring rates to be stiffer than this for an aftermarket spring, and also assumed the rear would be have atleast a 1 kg/mm stiffer than the front.
How does this compare to your guys spring rates?
