I'm servicing my 1997 MR2 G-Limited automatic and want to what type of automatic gearbox fluid it needs to drain and refill please?
Your reply will be appreciated.
RyanRs wrote:Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously, you don't know the answer to this? and you call yourself a car mechanic
benjo wrote:Hi 1 st I recommend dropping sump off the auto box clean magnets in sump and replace filter inside auto box about£30 from Toyota and is a service item,on mine it's says dextron 2 on dip stick but I've put dextron 3 in and been fine,also I'll have some spare bits for auto soon like mini ecu in centre console mine died and I bought new one from toyota.
madbasshunter wrote:Yes Dexron 2 drain and refill 3.4 litres(dry fill 8 litres)
http://www.autoshop101.com/forms/h17.pdf
I have removed the auto lever and boxes from mine(so have spares if needed) as I moved the O/D PWR and Man buttons to the dash and fitted a modified lever to my auto
[url]http://i536.photobucket.com/albums/ff327/madbasshunter/Purple%20Haze%20MR2/2016-05-17%2014.47.06_zps6ltpujuf.jpg
[/URL]
so it doesnt look like an auto![]()
