Porterfield Brake Pads
ashley
Re: Porterfield Brake Pads
Post by ashley »
It's difficult to describe- it's not a harsh noise at all, almost like a soft rubbing noise...very smooth, but you know they are doing something
JLW
Post by JLW »
Ah cool , well as long as it's not smooth enough to send
Me to sleep were all good lol.
Gonna order beginning of September, going to also go for a set
Of braided lines, and if I can find one, a "Cusco" brake stopper.
Can't hurt !
Gullzter
Post by Gullzter »
I'd say it sounds like a clicking noise, though I drive with windows down all the time so I'll always notice it :eye:
Not sure if that's to do with the discs if chosen, dimpled and grooved I went for :thumleft:
I got Goodridge braided lines at the same time, and new fluid..
Could do with a brake stopper though :-k
Nic
Post by Nic »
ashley wrote:It's difficult to describe- it's not a harsh noise at all, almost like a soft rubbing noise...very smooth, but you know they are doing something
Just out of interest, do you have the stock anti squeal shims fitted? I've always run without the shims as it gives you slightly better pedal feel but that is with OEM pads, wondering if you need the shims when using the fast road/track pads to keep them quiet.
Nic
[email protected]
MR2 Rev 3 GT Turbo
ashley
Post by ashley »
Nope- the Porterfields cam with shims, so I didn't fit the old ones off the other pads...I was going to see if I needed them, but not seemed necessary so far :thumleft:
JAAASH
Post by JAAASH »
Also running the exact setup that Ashley and Gullzter are. Mtec coated discs and r4s pads and they've described them down to a tee. Love the progressiveness of them and the dust isn't worth mentioning tbh. Coped very well, tucked up behind Ashley for a lot of the Pyrenees runs.
Definitely a set up I'll continue to use in future :thumleft:
_________________
"What the Deuce?!"
My MR2 - http://www.imoc.co.uk/forums/viewtopic.php?t=174494
JLW
Post by JLW »
JAAASH wrote:Also running the exact setup that Ashley and Gullzter are. Mtec coated discs and r4s pads and they've described them down to a tee. Love the progressiveness of them and the dust isn't worth mentioning tbh. Coped very well, tucked up behind Ashley for a lot of the Pyrenees runs.
Did you order from Whifbitz of whatever it's called as well
Josh ? You have any issues with the part numbers etc ?
Gullzter
Post by Gullzter »
I ordered from whifbitz :thumleft:
JLW
Post by JLW »
Gullzter wrote:I ordered from whifbitz :thumleft:
Might see if Paul at TCB can source for a better price.
if not then ill order from them. :D
SonicSW20
Post by SonicSW20 »
Let me know if you find a better price. I've had some luck previously ordering parts from US manufacturers via Amazon, saving quite a bit of money. Annoyingly Porterfield do have some listings on Amazon US, none for the MR2 though.
JAAASH
Post by JAAASH »
I ordered direct from Porterfield website
_________________
"What the Deuce?!"
SonicSW20
Post by SonicSW20 »
JAAASH wrote:I ordered direct from Porterfield website
Porterfield UK is Whifbitz :thumleft:
JLW
Post by JLW »
Having no luck getting any responses from the Whifbitz
team, Don't want to order the wrong pads.
Any ideas if these are the fronts and rears I need.
Fronts:
http://www.garagewhifbitz.co.uk/porterfield-499.html
Rears:
http://www.garagewhifbitz.co.uk/porterfield-494.html
Just like to speak to a human before ordering you know lol.
especially so they can tell you if its in stock or not !
EDIT:
looked on page 2 of this thread and have seen Ashley ordered the same part numbers, so I'm guessing these are correct.
ashley wrote:Umm....they told me the rears were the same for all revisions when I called, and I just ordered a "pair" of rears off the website:
No mention of "sided" :-k
I went with these for the fronts:
All for my rev3 turbo...hope they fit :lol:
Gullzter
Post by Gullzter »
Pretty sure that's what I ordered, have you tried calling them to confirm?
SonicSW20
Post by SonicSW20 »
That looks correct to me.
JLW
Post by JLW »
Gullzter wrote:Pretty sure that's what I ordered, have you tried calling them to confirm?
Twice , left a message and no reply, I'm 99.9% certain
That those are the correct pads, however it would be
Nice to know that they are in stock and delivery times etc !
Edit: since then I have called a 3rd time and spoken to Paul
He's mentioned they take about 10 days as are shipped from
America. I'll be ordering tomorrow.
Gullzter
Post by Gullzter »
Was just about to say, they don't stock them.
JLW
Post by JLW »
Ordered through TCB parts instead,
Paul's very helpful and gave me the same price as Whifbitz
did. Also ordered a set of HEL braided lines
and MTEC dimpled and grooved discs with a black protective coating.
One more question, Which Fluid ?
I believe the car has Miller 300 plus in it atm.
should i just used that again ?
Nic
Post by Nic »
I'd use either Motul RBF600 or RBF660
Nic
[email protected]
MR2 Rev 3 GT Turbo
SonicSW20
Post by SonicSW20 »
RBF660 is supposed to be decent.
EDIT - to be honest most of the DOT4 race fluids are going to do what you need them to do :thumleft:
