Hey guys
I want make sure is there actual diffrence between these two?
Ride height? Stiffness etc
Rev 3 turbo blisteins vs rev5 na suspension
Re: Rev 3 turbo blisteins vs rev5 na suspension
The Bilsteins are stiffer and are designed with the heavier weight of the turbo motor.
The UK NA shocks and springs are softer and use a bit less springrate due to the na motor being lighter.
As above, but if you're looking at a used set bear in mind they are 20 years old, and will be pretty xxxxx.
Is the right height is the same?
Shocks don't have an influence on ride height.
Use the suspension suited to the car.
