Forged build on way, then looking to take control of intake temps because looking for bigger power.
I'm really not clued up at the moment but know I have 3 options
WI
CC
Boot mount
Based on cooling eddiciency and cost, what do people recommend?
pbmr2 wrote:looking at charge cooling my new setup.might not do the standard style install but the basic idea is the same.
nice short pipe run for the boost pipe, super cool charge and little change in intake temps.it does add a bit more weight but it's not a large amount more and the system works better than an IC and is more reliable than WI, esp for long drives/regular use.
craig wrote:Chargecooler.Radtech pre-rad, Bosch cc pump.
Probably looking at a custom chargecooler.My set up was proven on Simon hicks 530bhp MR2.
Custom top mounted core using 2 chargecooler cores joined together.![]()
Pete will be able to give you the details.I personally wouldn't bother with a boot mount.
Long pipe runs, lag and you lose the boot.
Just my 2p.
Race Idiot wrote:craig wrote:Chargecooler.Radtech pre-rad, Bosch cc pump.
Just my 2p.
Why would you need a chargecooler capable of 530bhp for a ct20 lmao
androo007 wrote:Still really stuck between these 2 ideas.
Does a boot mount really need the adapted boot lid,scoop underneath and all chopping out? Seems a bit extreme!
What I do like about WI is the effect is has relating to increasing octane rating and physical cylinder bore temp.![]()
Not come across someone with cracks that's had it installed yet.
there are good failsafe and backups, but the kit is up to 600 quid plus install.
Martin F wrote:androo007 wrote:Still really stuck between these 2 ideas.
I sold a complete water injection kit, albeit an aquamist 1s on ebay and only got around£120 for it, someone else was selling one for
£400 so bargains can be found.
I got nervous and tried to cancel it with 20 hours to go but ebay said I couldn't do that, I was well gutted to let it go for so little![]()
