I was told by somebody that you could not regas the aircon in our systems?
I thought you could do it for any system even old ones, I thought that they may need to drain old stuff and replace with a newer different kind of stuff, but i thought i had seen summat on the telly that showed them doing something like this to an old jag?
If this is true I may as well disconnect my aircon belt and strip out all the gubbins, bit of weight savings at the cost of a hot cabin, but with our weather how often is that likely.
