Obviously it's a different car, but I run 8 degrees of castor on my laurel, the steering is nicely weighted and it handles brilliantly.
If you have rca's on the front and are using standard track rod ends your bump steer will be negatively effecting the handling massively, the Lower control arm and track rod need to move in the same arc, consider buying some SuperNow track rod ends
Also, looking at that sheet, your left rear wheel is toeing out and the right rear is toeing in? For a stable planted car you want a smidgen of toe in on both rear wheels which will naturally make the car want to drive it's self forward.
