japaneseskoda wrote:Thanks Shinny, that's really helpful, need to sort out them this weekend.Can you get the 205 type to fit the front or would you stick with 195?
japaneseskoda wrote:Gone with what you requested, thanks again, don't know what I'd do without this forum
shinny wrote:japaneseskoda wrote:Gone with what you requested, thanks again, don't know what I'd do without this forum
Requested? I just quoted the standard sizes![]()
shinny wrote:japaneseskoda wrote:Thanks Shinny, that's really helpful, need to sort out them this weekend.Can you get the 205 type to fit the front or would you stick with 195?
I guess you could go for 205/55/15s..
but that's not your issue.
The issue with standard wheels is finding a decent set of rear tyres.
Very few brans still make 225/50/15s and many that do are ditchfinders.
(MR2s do not respond well to cheap rubber)
Gazza_DJ wrote:shinny wrote:I guess you could go for 205/55/15s
I'd probably go 205/50R15 if I wanted to go wider on stock wheels, as I'd rather lose 5mm of sidewall than gain 5mm!
