ok, put on my big boy shoes and went out and found some cover and.
I'm confused.
Pulling the passenger side fuse
- makes no difference
(as expected) but tested fuse and it was fine.
Pulling both fuses gives nada, not even a dull glow
- both lights out completely
Both fuses checked and confirmed ok.
Third 15AMP fuse found and confirmed ok
Put the passenger side fuse in and passenger side headlight bright and drivers dull.
Put both fuses in and.
passenger side dull and drivers side bright
remove passenger side fuse and passenger side dull and drivers side bright
Swap the fuses about and both fire up their respective bulb without issue.
With both fuses in, passenger side headlight is dull as above.
I checked the fuses when they were inserted and the power was on.
Both fuses had 14.25 on both sides of the terminal
(probed through the gap in the top of the fuses)
