only a minor update, everything is all sprayed, laquered, all ready for refitting!
ive spend alot of time cleaning up the inside of the manifold, also wet sanding the matting surfaces on all the bits and inlet side of the head.
i decided to also spray up the fuel rail, map sensor bracket and while i was at it, the strut brace tabs.
also have my injectors back, cleaned and flowed test with all new orings from MrInjector.
very happy with the service.
was noted at higher duty cycles some pump a tad more more fuel than others, so i will be giving those leaner cylinders the injectors with the higher flow.
the injectors i removed, someone, i dont know who, installed crappy ill fitting orings on the bottom of the inside of the rail!!! they were mashed and clearly the wrong size.
the top and bottom orings are ment to be identical!!
completely wrong fit!!
guess which is OEM and the correct size, and guess which are some weird cut offs!
flow results
also decided to give the back of the bay a clean before the manifold goes back in
(still need to clean around it though, ha!)
all in all, a very time consuming job, as i am a little OCD with these things.
