I may regret this, however, the time has come to let my pride and joy go.
I have owned the car for 4 years after purchasing from Toxo here in Imoc, and this is my 3rd MR2.
Rev3 GTS Turbo Tintop in Caribbean Blue
The car is HPI clear
Odometer currently reads 101,500 miles.
MOT December
The car has 2 keys and 2 alarm fobs
Engine:
ST205 Chargecooler conversion
ST205 ECU
Berk exhaust and flexi section
Ceramic coated Blitz cast decat pipe
Ceramic coated turbo elbow
Ceramic coated exhaust manifold
CT20b turbo
Ceramic coated exhaust housing
Polished compressor housing
Gizzmo Phenolic intake spacer
Blitz intake SUS iduction air filter
HKS SSQV dumpvalve
SFS/Pacific Works intake hose set
GTech fan kit using 2 SPAL fans
SPAL PWM V3 fan controller
TRD Oil cap
Stef Derner clamping speedo converter and delimiter
New alternator a year or so ago
New cambelt
Transmission:
E153 LSD gearbox
TRD torque mounts supplied by Fensport
Fidanza Lightweight Flywheel supplied by Century Motorsport
ARP Flywheel Bolts
Goodridge braided clutch hose supplied by bobhatton
Speedsource shifter bearings and base bushes supplied by sbits
Suspension:
Rev1 rebuildable struts
Koni adjustable inserts
TRD top mounts
Eibach springs
All supplied and fitted by Century Motorsport and aligned by Wheels In Motion
Fully polybushed using Prothane polybushes
Cusco front tension arms and camber adjustment bolts, making the suspension more adjustable
Exterior:
Border style front bumper supplied by Pacific Works
TOMs style sideskirts supplied by JeffD
Genuine Airwalker rear bumper
Raybrig headlamps
96+ clear sidelights
96+ heated retracting mirrors
MR2 roadster
4-brake light rear conversion, rear fog using a Toyota UKDM rear fog light switch with the UK rear fog indicator in the instrument cluster
Rev5 rear spoiler
UK front numberplate mount to maximise airflow to radiators
Brakes, Tyres and Wheels:
Kei Racing Evo wheels in hypersilver 17 x 7.5
Goodridge braided hoses supplied by bobhatton
Refurbed front brake calipers
Completely rebuilt all the brake sliders and boots and carriers etc with new parts from Toyota, this cars brakes will not stick or jam for years and years to come
Genuine Toyota discs all round
Cusco brake master cylinder stopper
20mm hubcentric wheel spacers on the fronts
Toyo T1R 225/45/16 on the rears
Tyre Tread
Rolled rear arches
Interior:
Omori 45mm boost gauge installed in stock location
TRD/Recaro replica heated reclining seats
Black headlining
HKS CAMP engine monitoring system
HKS CAMP junction box
HKS CAMP boost pressure sensor
HKS CAMP temperature sensor
TRD gearknob
Rhon leather gearstick and handbrake gaitors
Stainless Steel Dial Rings
Toad Ai606 Thatcham Category 1 alarm
Toad alarm
Falcon total closure module
Falcon electronic boot release
Audio:
Kenwood DNX-7200 double din touchscreen satnav
Kenwood KCA-BT200 bluetooth hands free module
Reversing camera
Ipod adapter
Other Junk:
Has original JDM flare in passenger footwell and most of the original Toyota toolkit.
Car has NO ABS, NO AIRBAGS, NO TRACTION/CRUISE CONTROL.
The car has an extra
dyno'd at 284bhp at stock boost at Surrey Rolling Road in 2010.
Photos:
Some history:
I am the second UK owner.
Imported for me by Tom Solan at Northampton Vehicle Imports in 2006- seehttp://www.nvicars.co.uk/
- a reputable importer of MR2s and an affiliate on IMOC.
I am the only UK owner
(although I think for importing purposes NVI might be listed as an owner).
The car had all conversion work required for the SVA carried out by NVI and was converted to MPH at the same time.
It was supplied on-the-road, with a full MOT and 6 months tax.
When I purchased the car it had covered 53,000 miles.
The car was then garaged for a year before I could afford to insure it and use it on the road
Most cars of this age have a varied history and this one is no exception- it has had a few scrapes! I discovered that it's definitely had some repair work done to it in Japan prior to being imported.
However this was done to a very high standard and is nothing to be concerned about.
The car's also been in the middle of a 3-car shunt on the M1
- again, repaired to a high standard this time at the bodyshop of my choice.
Over
£1500 was spent on the car at this time and I have the receipts to prove it in the service history.
It does still have some superficial sill damage underneath one of the skirts
- both myself and the bodyshop didn't deem this significant enough to warrant cutting the sill to pieces as it hasn't even pierced the paintwork.
The car spent a few months off the road last year, while I got the turbo rebuilt, and the exhaust parts ceramic coated.When it was reassembled it transpired that some rust had fallen from the exhaust manifold into the head and the valves wouldn't seal anymore due to the damage.
The head was rebuilt by Pacific Works and the car reassembled.
All gaskets in the intake and exhaust system were replaced during this period with new, genuine Toyota parts, and the Hose From Hell was replaced.
A Gizzmo phenolic spacer was installed in place of the inlet manifold gasket, to reduce intake charge temps.
The injectors were ultrasonically cleaned.
The next time I changed the oil on the car I found some swarf in the oil, so I got Rogue
(who have now moved quite close to me!) to whip the bottom end apart and check for any damage.
The engine came back with a clean bill of health after an oil pump rebuild and has been faultless ever since.
To give you some kind of idea into the way this car has been treated and the money I spend on looking after it, off the top of my head the car has had:
New Toyota sidelights- old ones were mouldy
(Jun 2011,
£100)
New ignition coil, rotor arm, spark plugs, oil, oil filter, fuel filter all genuine Toyota(Jun 2011)
New coolant filler neck and radiator cap(Jun 2011)
New front ARB droplinks(Jun 2011, me,
£60
- NOT FITTED YET)
Bodyshop paint correction and tidying up the front bumper, and 2 years worth of stone chips/ car park dings
(Jun 2011,
£625)
SPAL fan controller(May 2011,
£110)
New wheel bearing(genuine Toyota kit) and wheel alignment performed by WIM
(May 2011,
£200)
Front suspension arms replaced with new genuine Toyota& Cusco adjustable parts
(Apr 2011,
£850)
Coolant flush with Toyota Longlife and new genuine Toyota thermostat and gasket(Apr 2011, me)
Kenwood KCA-BT200 bluetooth interface fitted(Apr 2011, me,
£90)
Engine bearings and head inspection, oil flush, new oil+ filter etc
(March 2011, Rogue Motorsport,
£500)
Stef Speedo delimiter installed(March 2011, me,
£70)
Oil changed again(+ filter, genuine, Jan 2011)
Complete head rebuild incl acid dip, new seals, pressure test etc and reassembly of engine with newly rebuilt/coated exhausts parts(Nov 2010, Pacific Works,
£950)
**HFH replaced at this point
Turbo rebuilt by bobhatton and balanced by Universal Turbos(Oct 2010,
£300)
Turbo compressor housing polished
Turbo housing, exhaust manifold, turbo elbow and blitz decat ceramic coated(Sep 2010, Zircotec,
£350)
Oil+ filter, rotor arm, dizzy cap changed, genuine parts
(June 2010, me, unknown mileage)
Kenwood stereo fitted(£350, early 2010, me)
New Apexi induction kit filter element(early 2010, me)
New genuine Toyota brake master cylinder(£250, Dec 2009, fitted by me)
DOT5.1 brake fluid flush(as above)
New genuine Toyota ECU water temp sensor(as above)
New genuine Toyota distributor cap(Late 2009 on 72000 miles, fitted by me)
New genuine Toyota rotor arm(as above)
New genuine Toyota HT leads incl.king lead
(as above)
New NGK grade 7 spark plugs(as above)
Brakes International refurbished rear brake calipers(as above)
New genuine Toyota rear discs(as above)
New genuine Toyota rear pads(as above)
New Goodridge braided brake hoses(as above)
New genuine Toyota oil pump(late 2009 on 72000 miles, Pacific Works)
New genuine Toyota water pump(as above)
New genuine Toyota driveshaft seals(as above)
New genuine TRD engine torque mounts(as above)
Oil change for 5w40 Fuchs Silkolene Pro S(as above)
New genuine Toyota oil filter(as above)
Fidanza flywheel fitted with ARP flywheel bolts, clutch inspected with"plenty of life left"
(as above)
Goodridge braided clutch hose fitted, clutch bled(as above)
Sump and strainer cleaned and refitted(as above)
Gearbox front torque mounting point reinforced(known weakness on E153 gearbox, as above)
New Gates cambelt(May 2009 on 68000 miles, Pacific Works) Note that I was told the cambelt had been changed before importing, but wanted to be extra sure)
Oil change for 5w40 Fuchs Silkolene Pro S(May 2009 on 68000 miles, me)
Complete coolant flush using genuine Toyota LongLife coolant(as above)
Gearbox oil change to Redline MT-90(as above)
An all important magnetic sump plug!
Early 2009 the car was detailed for a whole day by Ben(Tiny) who does 3S/TGT's detailing
- results here: http://www.imoc.co.uk/forums/viewtopic.php?t=114531This has had a lasting effect on the car and it looks stunning when polished with Autoglym HD Wax as I do.
Since then the car's bodywork has been looked after by Towcester Coachworks whos work is excellent.
In a nutshell, this is a well sorted rev3 turbo, with a proven history of being well serviced with genuine parts, producing excellent power at stock boost levels, with every common problem that occurs with MK2 MR2s already addressed.The hose from hell has been replaced, the brake sliders and calipers are new, the alternator is new, the droplinks are new, the suspension bushes are new, the ignition coil is new, the turbo seals and valve stem seals are new.
There is no rust around the sills or the chassis rails anywhere on the car, even the
'cancer bars' look like new.
Since my own owner ship the car has received a new battery and alternator, and has been serviced yearly
I have added the wheels as listed above and also the Rev5 rear spoiler.
There was a problematic earth so I added added a second earth strap to the battery which resolved the problem.
Rear Wheel bearings replaced.
Switch added to stop the aerial activating every time the ignition is turned on.
Front brakes starting sticking, after an attempted repair which worked for so long I ordered some recently refurbed callipers and had these fitted.
around 99,000 miles I noticed some oil loss, which lead to a compression test revealing poor results.
At the same time the cambelt was changed and timed up.
Since the rebuild the car has been absolutely spot on.
Due to the rad replacement the car has not been ran for nearly 4 weeks now, and I therefore need to give it a clean before any viewings.
The complete history of the car can be found in the link below which speaks for itself:
http://www.outlawjapclub.co.uk/forum/sh ... .php?t=506
Bad points:
Bumper has had something spilt on it in the past and therefore the paint work is not great in one area.
The bumper has a crack
Drivers seat shows some wear
Engine lid and bonnet have some minor areas that need touching up.
The car is 20 years old so please don't expect an immaculate example.
I think I have covered most things
Please feel free to contact me on 07817 923 244 or [email protected]
Based near Derby.
Rob
