Any MR2 Turbo Specialists in Scotland?
Re: Any MR2 Turbo Specialists in Scotland?
Cars fixed.
Turned out i got the crank timing mark wrong.
There's a very fine line on the rim of the crank.
I was using the notch the the crank pulley locates and slides over.
Should have asked Peter in more detail about the timing marks.
Feel like a right d*ck and
£300 lighter.
Although with the checks carried out on all electrical systems and the engine running spot on I ca now free off the brakes and get the mot sorted.
Big thanks goes out to all the guys on here who helped out.
I do appreciate it
- IMOC Moderator
great news man!! Seen a guy out in a rev1 tubo with the t-bars out today, I was in my diesel volvo estate so was pretty jealous
Regarding your
£300, At least you're out in the car and it's not having a dud engine hauled out of it, Forget the money and just be glad your not having to go through the summer without it
Regarding your
True man
Front brakes are binding, hopefully that's just the sliders, bang on a lower ball joint and the summers ON!
- IMOC Moderator
IMR2T wrote:True man![]()
yeah, free them off, make sure you use decent grease on them
I have quite a bit to do before my summer is on unfortunately
Your avatar gives the impression yours is mint big chap!
What's on your list?
- IMOC Moderator
I whipped the engine out at the end of the year to put forged pistons in etc.
.Been waiting a while on the block getting back but I collected it last night so all systems are go
Just need to rebuild it and get it back in the car etc.
http://imoc.co.uk/forums/viewtopic.php? ... highlight=
Build thread here, excuse the first few pages, I did ask for a mod to tidy them up
A tip: make sure you use the right grease on your brake sliders, normal grease eats rubber and will make them worse
(apologies if that teaching you to suck eggs!); glad she's running again!
ashley wrote:A tip: make sure you use the right grease on your brake sliders, normal grease eats rubber and will make them worse(apologies if that teaching you to suck eggs!); glad she's running again!
Not at all mate, my knowledge on different things will be patchy.
- IMOC Moderator
good advice, I put down a lot of the sticking issues down to folk
sheppy wrote:I whipped the engine out at the end of the year to put forged pistons in etc..
Build thread here, excuse the first few pages, I did ask for a mod to tidy them up![]()
Mate that would be epic! Was really close to getting a Rev 2 engine to put into mine, then rebuild mine to a reliable 350bhp.
Will def get a swatch at your thread
I used red silicone grease
something like this, can be had much cheaper
http://www.ebay.co.uk/itm/18g-18g-18g-1 ... 33a02a59da
Cheaper version
http://www.ebay.co.uk/itm/SILICONE-GREA ... 2ec7a7aa53
Cheaper version
On it! Cheers guys!
PW@Woodsport wrote
So i was bang on
110psi is low, it should be at least 150psi across all four, but the fact you have a consitent 110psi makes me think the cambelt isn't timed properly, which in turn throws your ignition timing way out..
Take the top cover off the belt and take some pics of the pulleys and also a pic of the crank pulley on TDC at the same time, something's not right there.
So i was bang on
Haha, yeah mate
